Jegs
I have a single cylinder diesel genny; without an alternator. Can any kind soul advise me how I might measure the number of revs?
Hopeful thanks,
John G
Hopeful thanks,
John G
Hopeful thanks,
John G
Get a non contact tachometer Like the one shown hereI have a single cylinder diesel genny; without an alternator. Can any kind soul advise me how I might measure the number of revs?
Hopeful thanks,
John G
Thank you for your helpful responses.
The genny is designed to run @ 3000 rpm but the voltage is 200/205 not 230. I thought that the problem might either be with the engine or the electrickery & decided that If I could measure the rpm I could either alter that, if incorrect, or eliminate it & go on to the electrical side.
The optical counter might be difficult to use without removing genny from outer case - awkward & heavy. It's at least 20 years old!
Many thanks,
John G
Thank you - didn't someone once say that wisdom is knowing how little you know?
The manual for the Laser generator, with Faryman diesel, is in Italian & does not appear comprehensive. My thinking [?] was that if the revs were down the output would drop, but it would seem from your reply that I was wrong. Would I be right in reading your reply to mean that even if the revs drop the voltage would not?
Thank you,
John G
