Richard10002
Some will recall that, whilst I was messing about with my alternator and charging regime, my rev counter failed.
It's failure coincided with removing the sensing lead from the alternator and extending it to sense at the domestic battery... all connections were made and unmade with the engine not running.
Most responses were that I must/may have disturbed a connection, but I have checked the connections in the vicinity, and remade them, and all seems OK, but the rev counter doesnt work so....
Is there a way of using the multimeter to test where the failure has occured.... e.g. if I can check that the alternator is outputting a signal, then I know it's further down the line etc.
also, is there a "something" I could connect directly to the rev counter, to see if it is working.... I understand it's an AC signal which runs the alternator, so maybe there is a way of feeding a variable AC signal of the right voltage or ampage or whatever, to see if it works.
I'm guessing a lot here, but I think those who know will understand what I am trying to do.
Many Thanks
Richard
Many Thanks
Richard
