pcatterall
The engine is on the bench, injectors are out and head is just back on with tappets adjusted etc.
Is it worth at this stage checking the oil distribution system is working by spinning the engine now ( without trying to start) and without the rocker cover on.
I have preoiled the cylinders and filled the sump.
My concern is that as the oil has well and truly drained out and some componants may be quite dry there will be some time for the oil to get around the system
and this may have adverse effects. Circulating the oil with no load seems worthwhile before fitting the injectors and other stuff?
Advice please!
Advice please!
