Sorry it was Spanish …..but basically self explanatory,The man who jumped aboard the yacht owns a sailing school ,he called up the rescue services.Well, that was, well, a weird voiceover.
Looks like it was one of those brick shite house buildsCan’t bear to look
Poor sod
Or just light enough to bounce?Looks like it was one of those brick shite house builds![]()
No y all accounts it broke loose fro its mooringA bit worrying that the hatch was open. Was someone lost overboard, perhaps, even though there appeared to be a mooring line trailing from the bow?
Go on Wansy, you should be able to buy her for not a lot of euros?Are you going to make an offer?
I can think of far more enjoyable ways of getting legless than coming between rocks and a boat being pushed against said rocks by waves.Go on Wansy, you should be able to buy her for not a lot of euros?
If the bloke who was doing the filming had simply gone to help the chap who was on board, and trying to motor the poor boat off the rocks, then they might have been able to push her off before the rescue boat arrived?
How cold is the water there at this time of year?
If there was an anchor and cable on board, it might have been worthwhile swimming the anchor out and then have one chap heaving on the cable and the other chap pushing at the stern?
Yes that was my first thought too .Go on Wansy, you should be able to buy her for not a lot of euros?
You’ve got to hand it to the boat for still being afloat after that.
Absolutely not. Even a small boat like that weighs around half a ton, and there is no way anyone can safelyhold the crushing forces even a tiddler like that can generate bouncing around. It will amuptate or seriously crush any arm or leg in an instant. Poling off would be safe enough, but never ever get between a moving boat and a solid object.It appeared that the keels were sitting on a ledge of rock in front of those rocks above water that the hull sometimes touched, and taking the main force of the waves rather than the hull. The keels on a Leisure 17 are solid metal (cast iron?) bolt-ons, not encapsulated.
I think it could have been done, or at least tried, without undue danger. One could have sat on the rock that the hull was hitting and pushed the boat out with your legs above water - either out sideways enough to be able to lower the prop fully into the water, or when it washed aftwards it might have spun round bow more to the incoming waves, then pushed it forwards by the top of the transom into deeper water. Alternatively, one might have tried to pull the bow into the gap in the rocks to the right of the picture and then push and motor the boat out backwards.
