ytd
our 2003 Bav 44 has wire genoa and main halyards spliced to rope as they appear from the mast. The main halyard wire is getting a bit rough and chafing anything it touches so I would like to replace them with spectra. The wire is about 5mm dia spliced to 12mm double braid. Only the braid goes on the winch. To fit over the masthead sheaves I'm thinking of using 8mm dia spectra. This should be strong enough and reduce weight aloft. The only disadvatage I can see is that it will make it harder to bounce the main halyard. Might need to check the teeth in the clutches too.
Has anyone done this? Anything I should look out for?
