bignick
Does anyone know whether it is possible to replace a Lewmar Ocean car without sliding it off the end of the track? I.e. by removing an end cap and removing the bearings? I want to replace the current one because the main (captive) shackle is half worn through. However, having had a good look underneath, I can’t remove the track without cutting many holes in the inner lining of the boat, guessing where the bolts will be. I can only presume that they installed the original mainsheet system before they fitted the deck moulding on the hull. There isn’t space to slide it off the end because of the cockpit coamings.
