replacing engine mount
john
13 May 2001
south west
one of my rubber engine mounts has been fouled by a diesel leak and is crumbling. Is it possible to just replace the one mount or do all four need doing and what is the procedure for doing this. the engine is a bukh 20. Thanks.
PaulJ
7 Jul 2001
Ipswich
I don't know the bukh 20 or indeed your specific installation but I suspect that you won't be able to replace just one engine mount without undoing all four, undoing the coupling and lifting the engine...... then of course you have to put it all back again and re-align the engine. Engine mounts don't cost the earth, particularly if you can find suitable ones at a boat jumble and I would suggest that it would be worthwhile replacing all the mounts while you are at it to avoid having to do it all again at some time in the future.
johnt
30 May 2001
you can get away with replacing a pair. front or rear,
you should be able to just loosen them from the bearers, jack the engine up enough to get them out and slip the new ones in, then tighten the new ones up again.
and engine manufacturers mounts DO cost a fortune! try R&D marine in Baldock i think it is
johnsomerhausen
1 Jun 2001
Vetus sells engines mounts for different engine weights at prices which are lower thdn the manufacturers'.
john
jfkal
17 Aug 2001
Singapore
Once you go throught the pain change them all and get the engine realigned properly.
Just replacing mine on a Bukh DV8. 279 quid plus vat and they are nothing special.
priced a set for my dv20 from bukh.just over £100 for the set,complete with bolts &
shims.
I replaced one mount on my Yanmar 1GM10 because of diesel contamination from a leaking fine filter. It was not a good idea as within nine months I had to have the other three changed. In Yanmars defence they were the original 13 year old mounts.
