bottomlesspit
hopefully fellow members can help.
Looking to have some work done on my anchor roller bracket. Beneteau. Appears to be held on the bow by 8 hex head bolts set into the fitting.
Questions:
I assume the through bolts screw into a in built base plate within the hull as opposed to some unable to get to Nut??
Fitting is also where forestay secures to. I assume I could use halyards to take temporarily replace the forestay whilst I have the fitting removed? Thinking just secure them to toe rail or the forward pulpit? (obviously yacht would not be used while in this state.
When refitting I assume it will need some sort of sealant underneath to make things fully water tight?
Comments/Experiences welcome
Questions:
