LeonF
Trying to replace the hull anode has turned into a major job. The nut refused to come off at the tip, ended up turning the bolt and breaking the seal, so going the whole hog and replacing the bolt. Just wondering what to use to seal it with?? Sika is too adhesive if ever I have need to do the job again...and should I be glueing the squate steel plate on the outside end of the bolt to the hull ? Any advice appreciated.
