robinwr
Discovered that we had lost our Beneateau style prop nut anode so decided to replace it whilst giving the hull a scrub before we head to Bangor for the winter.
Having just done it I'm now wondering if replacing this underwater is a good idea. Given that the screw locates in the nut is there a means of the water in the nut escaping as the screw is tightened or is the water pressure developed by the tightening nut going to be a problem. The screw seemed to tighten without significant effort so I'm hoping that it will be ok.
Best case scenario - screw loosens again (although this time I did apply loctite)
Worst case scenario - pressure causes nut to split and prop falls off.
This is in my mind as advice is to remove all oil and/or water when replacing cylinder head bolts after a cylinder head gasket renewal. Maybe this is because heat will exacerbate the pressure?
All experience and knowledge appreciated.
