Ardenfour
I need to replace all the windows in boat, they're all milky and crazed and leak like the proverbial.
So, um, acrylic or polycarbonate?
The vast majority of 'plastic' boat windows are acrylic. I assume you mean "perspex (acrylic) is harder, so is less likely to scratch"?Horses for courses, as far as I can gather. Polycarbonate is stronger, so will keep waves out a little better. perspex (acrylic) is harder, so is likely to scratch - though far from scratch proof. For an average yacht, I'd use perspex, for a high latitude blue water job, where I'm expecting the 'oggin to throw big lumps of itself at me, I'd consider polycarb.
Err, yesThe vast majority of 'plastic' boat windows are acrylic. I assume you mean "perspex (acrylic) is harder, so is less likely to scratch"?
[h=3]Toughened Glass Manufacturing[/h]Toughened glass is produced by heating a sheet of ordinary annealed glass to softening point (approx 620-640°C) then rapidly air quenching it. It is the speed of quenching that determines the toughened quality.
The air quenching solidifies the outer layers whilst the inner core continues to contract. The outer layers are put under compression and the inner core is put under tension. This builds a degree of stress in the glass which increases its strength to four times that of annealed glass. This gives it excellent resistance qualities.
It is in the heating and softening process that the forming and shaping of the glass occurs, including sag bending on a mould or pattern.
I suspect that the cost of making a precise former to suit one yacht would be prohibitively expensive.
Why can't you get curved glass? Car windscreens are all curved as far as I can tell. Surely this is quite a simple process to heat glass and bend it over a form.
