Replacement Props
TheBishop
22 Jun 2007
Need to replace ( possibly ) the props on my 1990 Trader 50.
What is best advice here on how to go about this? Boat based at Southampton...is there someone you can recommend who can have a look and quote for the job?? Do I need to dig out engine size info, shaft diameter etc etc...
All help gratefully received.
The Bishop
CJR Propulsion are at Bitterne Manor, right on your doorstep. I've used them several times and would recommend them without reservation. Brilliant service.
I have just had a prop refurbished by Steel Developments. They have done an outstanding job, as they have previously for me, at excellent value. Looks like new. Was well and truly beaten about, and suffering from galvanic corrosion, as one of the anodes on the outdrive have become loose.
They also supply replacement props in other materials
