Replacement log
Athene V30
20 Sep 2001
Playa del Ingles, Gran Canaria in Winter, the boat
I currently have a paddlewheel log that works when it feels like it if it has weed on it or not. I hate the process of lifting the log each time I have used the boat - I always imagine I am going to cross thread the blanking cap and sink the boat etc!
Before I go and test / replace the current paddlewheel arrangements is there a reliable means of measuring boat speed in a sailing boat without drilling a hole in the bottom of the boat or towing a length of line etc that can cope with slight weed build up etc?
I have a GPS but still want to know boat speed / distance through the water rather than measured over the ground.
Thanks in anticipation.
Use the old method of a long piece of string with knots tied in it. Don't know the exact distance between the knots but someone will be along in a while who'll know.
Tied to a log (literally) or something that floats let the string run out between your fingers and count the number of 'knots' over a given length of time. Suitable extrapolation will give you your spped through the water.
That's how it was always done before mechanical speed measuring devices were invented.
Bit of a kerfuffle, huh?
Good luck
