Replacement johnson pump lip seals
Rhylsailer99
19 Jun 2020
Just received my new pump, I have a replacement I ring to fit the pump but I have a feeling I need a lip seal as I can see the bearing on the pump. It has a lip seal inside but does another lip seal go on the outside of the pump
Google parts list for pump and check there may Even be an internal seal
You dont say what engine this is for but
From the impeller chamber you should see a lip seal
From the drive end , assuming it is directly driven from the engine ( not by a belt) you should see one of the bearings. There is not a lip seal between the engine and the bearings because engine oil will lubricate them
Sorted thanks the 2 lip seals are inside the pump back to back already fitted .should be out now on Thursday Friday chilling around anglesey with the kids ,I'm not a sailed yet so.need to make sure engine is 100% .
Managed to fit it today it's a bukh dv20 the new pump i fitted had a slightly larger diameter and I had to butcher the bracket a bit. Luckily I had a hacksaw on board.
