Replacement Hob Needed
Newbroom
26 May 2004
Woking
Trying to find a replacement hob for my Fairline T36. Cant find a make on the present one (which has been condemned by the gas engineer). The existing hob is a three burner and measures 470 x 390mm. There is not a lot of room to go much wider but could go deeper by probably another 80mm . Most of the ones I have found are much bigger or need a mains power supply for ignition.
Can anybody help
Can anybody help
It's most likely an Eno ?
http://www.marine-chandlery.com/par...m_medium=cpc&gclid=CPPtn-Co_csCFQccGwodSLoA9A
There are pictures here of the upgrade I did to the galley on my Turbo 36. I used Thetford Spinflo Triangular Hob & Sink. These are still current. Worth looking at caravan equipment suppliers for other hobs.
I quite like the look of this one for my next upgrade - Ebay item 141809379559
To fit the Sharp vented combi microwave I had to move the left hand bulkhead ~50mm which meant dismantling the entire galley, and this included a new piece of teak faced ply for the front panel. I have recently used the door cut out piece for a new dash panel on my Corvette.
www.turbo36.wordpress.com/improvements
Thanks Peter yes I did see it and I am following different leads from suggestions received.
A likely alternative to whats fitted is a a Spinflo Triflex hob and oven.
I am trying to avoid a mammoth galley re design and looking for a a similar size alternative.
The original hob was an Optimus and the Oven was a rose (never heard of them)
If that's the Optimus hob I think it is then the Eno is a straight swap fitting the same cut out, Rose were quite common ovens a few years back there's a limited amount of parts still available but getting harder to get now.
Eno is 468 x 388 mm
Peter thanks very much, Penguin have them in stock. Strange as they were not listed in a google search.
Nice and local to collect from as well.
Dont suppose you know where I can get replacement rubber seals for the fuel filler caps do you.
Thanks again
Dave
Thanks again
Dave
I usually get O rings for filler caps from Allseals, not yet been able to get from manufacturer/supplier of deck fittings.
