Replacement grills for deck speakers
saltyrob
11 Apr 2004
Suffolk
Hi folks,
The plastic grill covers on our deck speakers ,approx. 100/125 mm circular have perished and I would be grateful if any one knows where replacements can be purchased . The speakers themselves are fine so would be pity to have to replace whole unit. If not possible to replace grills ,is it possible to buy a small sheet of thin white perforated sheet and fabricate my own grills
Many thanks,
Rob
I have the same problem, kicked the speaker several times last year not much of it left. Looked in maplins if I was wanting to set up a PA system on deck they had it all. After a fair amount of searching I ended up buying a new speaker £16.50 the grill is exactly the same 135mm Dia. I will change the speaker and silicon it into the backing plate. Then later on this year I will kick the grill again.
