Gypsyjoss
Hi Sailors
I have a worn out Stuart No 2 engine seacock in the cupboard below the galley sink which I wish to replace. The hull fitting (flush), seacock and strainer are all combined into one bronze fitting which make it very compact in height and easy to rod from the inside in case of an external blockage. I think it's half inch.
Does anyone make anything similar with a through hull fitting, reasonably priced, because the combination of separate thru hull fitting, seacock and strainer is rather taller than I want.
Cheers
Cheers
