Replacement flexible coupling
gm4caq
Active Member
10 Apr 2005
Central Scotland
Hi,
A propshaft flexible coupling has failed on my dad's Colvic 30' yacht.
The coupling looks like a disk of 18mm thick rubber with two 3mm thick metal disks bonded to the rubber. The coupling flanges then bolt to the rubber.
It is about 6.5 inches OD with a PCD of 4.25 inches. It looks like a Metalastik coupling but they no longer seem to make these.
Gearbox is a TMP 2:1 reduction.
Norris Marine can't help, and still awaiting an answer from R&D Marine. Is there anywhere else we can try?
Regards
Bob
Hi,
Regards
Bob
Is the PCD the same on both gearbox and prop coupling and are there 4 bolt holes on each of the flanges??
Hi,
Regards
Bob
ASAP Supplies have them
failing that contact Kevin @ http://www.thameswaymarineproducts.co.uk/
flexible coupling
Hi
The PCD is the same on the gearbox and shaft flange, with three holes on each.
It seems to have relied on the vulcanisation of the 3mm disk to the rubber.. that has lasted many many years. until now!!
Regards
Bob
Hi
Regards
Bob
I thought I recognised your description......This is a type of coupling used on some early cars. My Austin Seven had one....I mean Austin 7 and not mini
The problem may be getting the 6 hole flexible connection .
There were enquires on here about these some time ago. I shall put on my thinking cap.
http://www.renold.com/Products/Couplings/Couplings.asp?menuID=24
Something like this????? The top picture???
Not really marine but have seen them on boats.
Replacement Coupling
Thanks for the suggestions folks.
Not heard back from R&D yet but it looks the best bet... if not the only bet...
TMP simply say that Metalastik no longer make them and recommend changing the complete coupling.. quite a big job with the boat in the water.. big job if its out of the water!!
Plenty of good systems out there.. but a drop in replacement that lasts another 25 years would be great.
Cheers
Bob
I've been there and done that - I found R&D extremely helpful on the phone.
Turned out they couldn't help in my case, 'cos my engine dances about more than their coupling could cope with. Unfortunately the details of the supplier I used are on the boat.
