clivew05
At the moment I have the following:
RL70C Multifunction Display chart Plotter
RN300 GPS with Antenna
ST50 Speed
ST50 Depth
4KW Raymarine Dome Antenna
ST5000 Autopilot.
I need to change the RL70C to one that I can actually see!! I tried using the RADAR and the Chart Plotter this weekend for the first time and found that its ok as a RADAR display and ok as a Chartplotter Dicplay but dont try using both at the same time as in split mode the screen is too small and in overlay mode the screen is cluttered.
So I got on to Raymarine who told me very helpfully - if I wanted to upgrade anypart of the above I would need to upgrade it all as none of this equipment is compatible with their current range of equipment .....
I have now come to accept that I need to spend £1000's on this but tell my self that it will be worth it in the long run ... the one thing that I have not yet sourced is a material to cover the holes in the console as - not only is the equipment not connectable to the new stuff but - the holes are different sizes ....
Now my console is a dark walnut - and I need to find a material of a similar colour and texture to cver over the holes so that I can fit the new equipment in.
My question then after all of the rambling above is does anyone know where I can get this from? Ive checked the local chandleries and DIY places with no success ....
Thanks in advance
Clive
ST50 Speed
ST50 Depth
ST5000 Autopilot.
Thanks in advance
Clive
