Replace water tank capacitive level sensor
andyp
22 Oct 2009
Gosport
I’m looking for two things: a supplier for an equivalent sensor and a way of removing the damaged thread from the tank-top...
I had a leak in the pressured leg of my FW system between pump and accumulator. Not enough to see except for the odd accumulator overrun, but obviously enough over time to damage the nearby FW tank sensor so much that the sensor now pulls out of the tank instead of unscrewing!
I can see it is an E-T-A NR60W1B which should have an M14x1.5 thread on it.
E-T-A seem to have moved into power relay switching devices and my googling can find a data sheet and nothing more.
More importantly, how do I go about removing the threaded section which has sheared off and is now wedged in the tank-top? Any ideas?
Will post photo later...
