mickywillis
During the winds we had a couple of weeks ago, my little Dabbler dinghy was blown over (leant against the side of the house) and landed onto a metal section of a dinghy trailer.
The metal strut went into the main body of the dinghy, near the bow and penetrated the outer layer, through to the foam core underneath. There is also a smaller hole near the small plastic bow cleat on the same section of the dinghy.
Couple of questions really, 1, what is the material the dinghy is made from? Doesn't appear to be GRP, definately not polypropylene, but seems to be a form of rigid plastic?
2nd, how can I repair it? Can I repack the cavity with offcuts of say Celotex foam (building insulation with the foil removed) to give support and bouyancy back to the structure and then use a polyester resin/matting to build up and finish with filler and then gelcoat over the top? Or do I need a specialist type of filler to rebond this plastic material?
3rd, what colour would you call the orange part? Although faded, I was thinking of a pastel orange or tangerine? Its not as bright as say a RNLI RIB hull, but not as orange as an orange?
Any info gratefully received!
