Achillesheel
We have an Achilles 24. Part of the coachroof is sagging slightly, and the core is black when viewed from underneath.
We intend to repair this over the winter. I understand the technique is to drill small holes in the affected area, use an Allen key in an electric drill to cut up the affected core, hoover the bits out, and fill the resulting space with resin. Finally filling the holes with epoxy filler.
I doubt it is as simple as it sounds; has anybody done this? what filler should I use, how big do the holes need to be, how long should I leave the holes open to dry, how do I get the filler in the holes, and above all, will it work?
At least I do not have to worry about what it will look like, because the repair will be covered by the decklining, but I want to stop the rot spreading, and ensure the strength of the deck.
Any hints, tips, and/or advice greatly appreciated.
