Colvic Watson
Anyone done it? Is it easy/difficult? Ours only has a few mm’s left on the adjuster, do we leave the packing in and add more or take it all out and start again?
Thank you.
Thank you.
My admiration for you has gone up leaps and bounds.The only thing that was difficult was sticking my head in the bilge and my feet in the air - if you have another option - go for it!
Undo it all, rack out all the old 'tat'. Cut the packing into 3 or 4 complete circles (do it round the shaft). Insert each ring, one by one, nicely and evenly. When sufficient packing, add on the adjuster. I find it almost impossible to verbally explain how tight the adjsuter should be. Clearly the packing ought to 'grab' the shaft but it ought not be so 'grabbed' that it needs a very strong wrist to turn the shaft. A little trial is essential. I suppose the best way I can describe the tightness was 'just a little tighter than it was before (which was dripping a little too much). I would like to claim that I was able to judge exactly how tight it ought to be but the truth is I had a little turn, thought it was a little tighter than before and then waited for water and running the shaft. It turned out it was (accidently) perfect - not actually dripping at all.
As she said however in my case it involves diving head first over the engine, ending up with lower abdomen resting on the last cylinder of the engine (don’t wear a belt it really doesn’t help, except for rescue party retrieval). Elbows on the hull stopping you head butting the prop shaft, inserting packing and tightening with your finger tips.The only thing that was difficult was sticking my head in the bilge and my feet in the air - if you have another option - go for it!
Thank you. Seems more possible than I thought. Does packing come in different sizes?The only thing that was difficult was sticking my head in the bilge and my feet in the air - if you have another option - go for it!
He is right, to some extent.Hi CW,
Yes it does, measured either in eighths of an inch or mm and it comes square. To determine the correct size, measure the bore of the stuffing box then measure the shaft diameter, subtract the second measurement from the first then divide the result by 2. If you cannot get exactly the right size, don't worry - you can adjust the size by putting it on something solid and hammering it- it will get thinner in the way your hitting it and fatter in the other direction. The length you need for each turn is pi x the shaft diameter where pi = 3.14. It's best to cut the ends of the turns at 45 degrees and is easily done by putting 3 or 4 turns touching each other tightly round the shaft in an easily accessible place, then make a single cut at about 45 degrees through them all - this will give you a 3 or 4 pieces of the right length with the angled ends..
The best type of packing is mixed with ptfe and that's what most suppliers will sell you these days.
There's plenty of guidance on line such as this:
How to repack a Stern Gland - step-by-step - Practical Boat Owner
Peter.
If doing the job in the water cut your rings and a spare first so you get minimal water inrush, otherwise you will be frantically cutting while gently sinking.
My first boat (Anderson 26) was lovely but engine and sterngear access was headfirst down the quarter berth... I replaced her sterngland with a Volvo seal, but wished I hadn't. Burping the seal required a one handed press up at full arm extension!Every time I read threads like this I bless the day 25 years ago when I was persuaded to give a Volvo seal a try. Never looked back - and the latest Radice version is even better.
