ryansdesk
New Member
Hi, i am restoring the hull on my GRP sailing dinghy, hopefully to a very acceptable finish. At the moment i am sanding the hull down to get rid of the previous owners paint brush ridges which are evident over the whole hull, i have been sanding this down with a wet and dry paper grade 180 but its taking far to long and my arms abvout to drop off, i was thinking of using a more course paper, say about 120, to get rid of the ridges and then go over it with the 180 paper before giving it a first coat. I wondering if this is a good idea?
My other question is to do with the actual paint, my origianl plan is to use international prekote below the finish coat of toplac however looking at the back of the prekote tub i may be better haveing an initial layer of primer over my newly sanded hull instead of just prekote. Bearing in mind that it is a GRP hull which will have some of whatever coated the hull in the first place still left on it in parts, whats the advice here,
Primer, prekote, toplac or just prekote and toplac?
