There is a gas powered hot hair gun arrangement used for shrink wrapping pallets that or something similar could do it. Perhaps hot or boiling water in some way.
Heat really is the best way and makes removal very easy. Without it you are in for a long job and risk scratching the hull. Any adhesive remaining can be removed with white spirit. Very careful use of a gas flame could be tried, but at the risk of scortching the hull.
Excuse the spelling but MEK--- Methyl Ethyl keytone
[/ QUOTE ] Absolutely no excuse what so ever.
Methyl ethyl ketone but now often called butanone. It is very similar in properties to acetone (propanone) so prolonged contact with the gel coat perhaps best avoided
Hairdryer more than suffiecient IME, even if just using a hairdryer you can get it a bit too warm if you get too close and the glue gets gunky and requires cleanup afterwards, not the end of the world though, as others have said a bit of white spirit makes it all ok.
Second all the comments others have said about trying to sort out some portable electricity, it really does make it much, much easier.
He wouldn't want to use that without a battery charger. Forgive me for commenting but as it is an open forum, isn't that pretty self-defeating as a starting technique? Diesels need speed to start far more than heat (fast cranking develops heat by compression in the head, where it is needed). What do you blow the warm air onto?
