ripvan1
With a spongy foredeck and fearing disintegrating foam between the two grp skins, I have cut off the outside skin to access the core. This was after reading up on other forums and against some advice on others to drill up from below and squirt foam in holes. (Glad I didn't go this route)
There was a lot of moldy sodden foam there (don't let anyone tell you this stuff is water resistant) but its all out now and cut back to sound and un-deliminated foam.
As it's a relatively small and flat 2ft x 4ft area, my intentions are to put one layer of gsm over the lower skin (from above obviously) put down 9mm sealed ply then building up a few layers of gsm, sand, fill, sand and gelcoat.
As a novice to this grp lark and getting most of my info from reading up on the web and asking about, does the above seem about right or am I missing anything.
