Looks like the last owner has hand painted on domestic white paint over the GRP. I want to get it off, will Nitromors or similar damage the gelcoat? Any other thoughts?
Ordinary Nitromors will damage gelcoat. There's supposed to be a special Nitromors for fibreglass, but opinions are mixed about it. You might try Dilunett (now called Marine Strip), which is safe on gelcoat. Or Interstrip.
If you can get a small quantity of acetone, test it on the gloss paint. Some paints soften with acetone and some dont. If it does, you can get larger amounts from any GRP shop
Be careful with acetone - it can soften gelcoat too!
I've had mixed experiences with paint stripper on GRP. I used Nitromors on a GRP car once, with no trouble at all, but splashed some on my boat once, when stripping a toe rail and within about 30 seconds the gelcoat was bubbling!
I've just come across a stripper for GRP called 'Enviromose' from builders merchants. It was about £45 for 5 litres and works really well. It also doesn't take your skin off! Google it to get more details
I have used polycel advanced paint stripper, its solvent based. I had to strip the paint from the moulded in non slip just to make things more difficult. I'd paint the stuff on, wait a couple of hours then blast it off with a pressure washer. I did have to repeat a few times as there were several coats.
Not sure how much paint we are talking about, but when I remove painted on boat names I use spray-on oven cleaner! In Canada it's called "Easy-Off", not sure about UK.
Does not affect gelcoat.
