BarryH
Removing an anode and need to fill the holes. Recommendations
My old VP2003 was bonded to a hulls anode (semi-pear shape). New engine doesn't require this so was thinking of using the anode to bond to the skin fittings.
Personally with small holes in a decent thickness of hull I'd taper the holes from each side, fill with a filled epoxy and finally glass over the inside for good measure with glass cloth and epoxy.
Cheers gents, I can do the prep work but I think i'll wait for the weather to warm up a bit before slathering glass and epoxy on it!
If you are removing the hull anode, what anodes will be left to protect the prop and shaft etc ?
The boat started life with a sail drive and inboard. Someone, before I got my mitt's on it, took it out. The glass work to fill the hole is very good. So the surveyor chappie said.. If I'm honest I've dragged my heels over removing the anode. Also decided to replace the outboard this year. circa 1800 quid rather than the 3 to 5k to replace an inboard. On this size of boat I don't think an inboard engine is worth the hassle or expense. Plus I have a huge storage area under the cockpit. Win win situation.
