It is fairly straightforward from memory - I removed and serviced mine some years ago when the shaft bearings collapsed due to corrosion. The pain is the need to remove all the volvo-style connecting piping and then refit with all the required new end seals on each pipe. You will have to remove the alternator and the heat exchanger if I remember right.
A bit like a Chinese puzzle . If you are forcing pipes sideways you are not doing it correctly and may well have to remove what is connected at the other end of that pipe and then you will be free to just pull the pipes out of the water pump. Get a packet of the seals before you start.Thanks for those encouraging words .......
The one of my VP2003 needed to be fixed. The nuts were rock solid and rather than risk bolts shearing I took the cowards way out and got a mechanic to do it. It was not serviceable. In the scheme of things boats a replacement from Keypart wasn’t too much.
Let me know how it continued. Pulley needs to be taken off and sealing and gaskets including shaft with attached bearing needs to be changed on my pump.
Well done removing the pump! I too used a refurb kit - but you need a decent press to remove/refit the pulley and the bearings from the housing. Mine failed while away cruising, managed to remove the pump and have a refurb kit sent overnight courier to Oban, thence by car to Tobermory. I spent a pleasant day in Tobermory with a local engineer who had a small workshop and crucially a decent press. Was up and running by the evening. I always used to keep a full set of the copper tube seals on board as part of essential engine spares kit!
As mentioned, replacement pumps are mad money, but refurbish should work fine
How is it going with the repair of the pump?
