prv
New boat has a Volvo D1-30F. This engine is clearly designed to be serviced from the starboard side, where all the service items are neatly arranged. Trouble is, mine is a re-power in a boat that was clearly designed for an engine that's serviced from the port side! The starboard side of the engine is hard up against a solid bulkhead, with restricted space above it too. Cutting access panels in the bulkhead isn't really feasible, most of it has the fibreglass heads liner on the other side which I want to keep intact for showering purposes. So, my plan is to fit remote mounted oil and fuel filters in a more accessible place.
Here is a picture of the starboard side of the engine (linked because it's BIG
For the fuel filter, it looks like I can simply demount the filter head that's on there, replace the hoses with longer ones, and mount it as required. It's likely that it will have to be slightly higher than the engine (limited space) but it has a bleed screw and a hand pump (and I can fit a better pump if this one turns out to be a bit feeble) so I'm not too worried about that.
It may be that for plumbing reasons it's simpler to go tank -> initial filter -> engine filter -> lift pump -> injection pump rather than the conventional tank -> initial filter -> lift pump -> engine filter -> injection pump. Is there any reason to prefer one over the other?
For the oil filter, I guess I need a suitable extension kit. Never used one of these, but I guess it's related more to the type of filter that it "pretends" to be than to the engine, and hopefully this relatively new engine uses a standard filter so there will be a kit available. Do the kits generally come with hoses of a fixed length, or do you add your own? No real idea what oil pressure is involved; are hoses a simple nipple and jubilee clip affair, or made up like hydraulic hose? Is there a limit (within reason) to hose length? Again, my preferred mounting location will be slightly above the engine - is that OK for an oil filter?
Doesn't look like it's possible to move the dipstick, so hopefully it will be reasonably accessible over the top of the engine. Nice to see a takeoff from the sump already fitted, and I will be adding a hose and pump to that.
Half a dozen question there; all answers welcome
Thanks,
Thanks,
