Strathglass
When I plumbed my boat I fitted two expansion vessels.
One at the cold water at the pump and a second one at the hot water outlet from the calorifier.
There is also a non return valve in the cold water feed to the calorifier.
The pipe from the pressure relief valve just goes to the sump under the engine.
When the engine heats up the water expansion in the calorifier is handled by the second expansion vessel and no water comes out from the pressure release valve.
Thus I do not have to worry about an additional hole in the hull.
The safety aspects in the case of a catastrophic failure are still covered with the pipe from the pressure release valve to the sump under the engine.
Iain
Iain
