Parisianzee
New Member
Hello all!
In the continuation of me discovering my new-to-me 1998 Regal 242, I have made a bad discovery a couple of days ago.
I knew the bilge under the mid-cabin was a bit oily and dirty from the photos taken during the survey, but I had never imagined it to be this bad. When I opened it, I realised that the shower sump pump was not working and the box in which it sits was full of water, as was the bilge everywhere around it. You can see all the photos and details in this blog post.
Armed with a bucket and a hand pump, I pumped out about 10 buckets of filthy water which I equate to roughly 50-100 litres. Then I open the shower sump pump's box and emptied that too. Once that was done, I tried to see if there was any power coming from the cables into the pump: nothing, 0.
With this very high level summary ... I'm left with two key questions:
- Does anyone have any idea where I need to start searching for power on those cables to either re-establish power to the pump or just replace the probably dead pump with a new one? I started looking for a fuse of some sort somewhere but couldn't find it. And the hole to access that bilge is very tiny. Any pointers would be much appreciated!
- How do I get the bilge properly clean? I believe it's not supposed to be wet and disgusting down there? Unfortunately after removing all that water, all that is now left is a very thick oily substance that will not pump out with my hand pump, and that is equally almost impossible to remove with a sponge (the sponge won't absorb it). Again, any ideas?
Thanks for your help, all!
