Wandering Star
This has to be a very vague cry for help as my V27 is in Mallorca and I forgot to make notes before I flew home. I'm flying back out mid July and would like to source any part I need before then. So here goes.
The V27 is fitted with a Bukh 24 engine and slung on the side of this is a fridge compressor belted off a second pulley. Inside the fridge is what I believe is referred to as a holding plate? from memory it's about 14" x 10" x 3" - a sort of rectangular stainless steel box which should freeze up and remain cold, I've seen the same frost covered holding plate at boatshows. I've never used this system in my 6 years of ownership.
Midway between the engine driven compressor and the holding plate, there's a small black box with a switch, a couple of LED's and inside, a small PCB. This little black plastic box has Thermocool printed on it and is damaged physically and broken electronically. I've done a Google to try and identify the box but with no joy.
I think (I don't know) the box is probably used to electronically engage or disengage some sort of clutch device between the compressor and the engine, tracing the wiring would tend to support this idea - does that sound reasonable? If that's all it's doing, could I replace the box with a simple on/off switch? What are the LED's for? what's the PCB for?
I don't want to blow anything up so I thought I'd ask for advice here before I try a repair! I'm sure the system will also need re-gassing too but I'd like to get the basics working first.
Ta everso.
Cheers, Brian.
Ta everso.
Cheers, Brian.
