Reefing and tidying up the bunt
matt1
11 Feb 2005
Hamble, UK
My mainsail doesn't have any reef points between the luff and leach cringles. It was almost certainly envisaged from the outset that it would be married to a stack pack, however for offshore sailing I want to be able to roll down the stack pack and lose the extra windage / chafe etc . How would I tidy away the bunt if heavily reefed without any reef points?
capnsensible
15 Mar 2007
Atlantic
I always thought that part of the fun of sailing was getting chucked around on the coach roof putting sail ties in the reefing cringles in bumpy seas and pouring rain.....
When I had commercial yachts however and mainsails were a more frequent buy than when cruising, I found a good sailmaker and took his advice. Sail ties in reef points will chafe your sails and I can sell you more! Don't use them! I took that advice.
Bit drifty but his other top tip was regarding had sail sun strips. Short lived in sunny places. He said unpick and remove the old one yourself. My labour will add a lot to the cost of replacement. Did that too.
Poignard
23 Jul 2005
South London
I have a book somewhere that shows reef points that don't have eyelets in the sail. Instead they are sewn onto either side of the sail and the 3 strands of the end attached to the sail are unpicked to form a clover leaf pattern. The free ends are tapered and whipped because tapered ends cause less chafe.
All very tiddly.
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
One can imagine some cobbled-together mechanism like an overgrown fold-back paperclip or a magnetic clamp. But any such devices would be unattached and thus a liability especially in reefing conditions. I think having cringles fixed is the only possible solution. If the sail is low-tech and/or cheap and small maybe it could be DIY...
johnalison
14 Feb 2007
Essex
I think that my sail has a seam or is reinforced at the level of the reefs and cringles. It would be a mistake just to insert cringles into a single layer of cloth, I would imagine.
matt1
11 Feb 2005
Hamble, UK
These are Elvstrom laminate sails. They have the reinforcement strip across where the reef would be, just no eyelets. Was spec'd as part of a new boat order and came with a stackpack so maybe they just consider them superfluous with that set up. I just wanted to check I hadn't missed anything obvious before I get some eyelets added. Thx
DJE
21 Jun 2004
Fareham
www.casl.uk.com
We've got eyelets but never use them. The reefed part of the sail stays fairly neat and close to the boom on its own. At 2nd reef we usually put a sail tie round the boom and through the leech cringle to tidy up the outer end of the reef and improve visibility under the boom.
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
Agreed. It would be good to reinforce with, at the least, some sail repair tape. And then have the challenge of making a neat hole through the lot! I am sure I have read that the cringles, other than the luff and leach, should not be tied down so tight that they take an appreciable amount of tension but merely to retain the bunt.
anoccasionalyachtsman
15 Jun 2015
I'm with @capnsensible and @DJE - you don't need them. a) The sail hangs fine without them. b) They're usually done up too tight and may actually damage the sail, and c) I saw one left tied when the rest of the sail was released. Messy.
GHA
26 Jun 2013
Hopefully somewhere warm
It can actually be quite handy having a bunt of sail at the boom offshore, with a reef in it's handy for catching water with a bucket under the gooseneck.
I've never bothered tying up the bunt on ocean passages, sail is fine.
Buck Turgidson
10 Apr 2012
Zürich
When heavily reefed use the stack pack. windage will be the same or less than the bunt. When on full tie the lazy jacks to the mast if you must. I notice all the Vendee Globe sailors are using stack packs.
DJE
21 Jun 2004
Fareham
www.casl.uk.com
I should add that we have lazy jacks but no stack pack.
dunedin
3 Feb 2004
Agree. Was reading recently a very experienced offshore sailer (poss Pete Goss) also recommending not using them - having seen a sail ripped into vertical shreds by the reefing ties. He suggested adding a cringle midway between the reefs, not for a rope but to allow water to drain out.
Poignard
23 Jul 2005
South London
There's a lot of sail flapping when you're on reef 3.
Yes, and it could hold many gallons of water at 8.6lbs/gallon if a big one comes over; which could delay the yacht righting herself after a knockdown, and might damage the sail and ruin its shape.
I'll stick to tieing in my reef points and try to remember to untie them before shaking out a reef. ;)
TonyMS
Winter St Ives, Cambs; summer Ionian
www.montgomery-smith.org
On our cat, I've arranged for the statpack hoist to go over a pulley under the spreaders, down to the foot of the mast, and then aft to a clam cleat on the coachroof. So, we can lower and hoist the statpack as we sail along. We also have a set of "anti-lazyjacks" that run from where the lazyjacks are attached to the statpack, along the boom and back aft along the coachroof, so that we can pull the lowered statpack tight to the boom.
Allows us to keep everything tidy and avoid chafe, at the cost of rather a lot of string.
TonyMS
