kita18
New Member
Hello- I recently became the happy owner of Aurelia, a 35' Bermudan sloop, built in Lerwick in 1954. Mahogany planks on oak frames and surprisingly dry in the bilge. She was moored in Arisaig and I am working my way round to Rosneath for the winter. I'm scratching my head slightly about the reefing setup, so any advice appreciated....
The boom is a solid spar of douglas fir and appears to be set up for point reefing- there are coombes and sheaves at the three reefing points. However there are no cleats on the boom, just two brass winches.
On the mainsail, there is a hook on the tack cringles for a shackle on the gooseneck, and there are cleats on the sail at the reefing points above the clew.
For the outhaul I am currently running a line from the clew to a block on the boom end, and then forward to one of the winches on the boom.
My questions are:
When reefing down should I release the out haul from the clew and reattach it to one of the leech reefing points OR leave the out haul as is and run one of the reefing penants from one of the leech reefing points through another block on the boom end and then forward to the OTHER boom winch.
The latter seems to make more sense but then I'm not sure what winch I should use for the down haul- the other two winches on the mast are in use for the jib and mainsail halyards.
Also what are the cleats on the sail for if the reefing penants are tied to the boom and hauled in by the winch?
I've been tempted to use the smaller cringles as part of the point reefing system but I'm pretty sure they are just for tying the sail down once reefed, but any reassurance on that point appreciated.
I know this should all be pretty obvious but the setup seems to be a mix of different systems and I'm unsure which is the right one.
Any ideas appreciated.
Cheers,
Felix
My questions are:
Cheers,
Felix
