Talbot
I Faxed my MP abt Red Diesel and he fwd this to the appropriate Minister (David Jamieson (david.jamieson@dft.gsi.gov.uk)) The following is his response:
"A comparison between petrol and diesel in marine use inevitably revolves around power/weight ratios of engines, and the safety issues of fuel stored onboard and unintentional ignition. Petrol is used most commonly for high speed applications. The use of petrol outboards for high speed boating and the associated sports of water skiing, paragliding, and petrol inboard motors for jet ski are particularly well known. Where lower power/weight ratios are acceptable and where greater reliability is necessary, diesel engines are preferred, and indeed are the only practical option.
Particular requirements in the EU Directive on Recreational Craft acknowledge difficulties in the stowage of fuels having a flash point below 55 deg C, requiring that tanks are not part of the hull, are insulated from the engine compartment, and are protected from all other sources of ignition. As you will appreciate, this places petrol at a disadvantage, limiting its use significantly. <font color=blue>Petrol engines are also inherently ill-equipped for anything more than use in relatively calm conditions due to the limitation of the ignition system.</font color=blue>
Despite the removal of the "Red" status of diesel, the relative benefits of diesel as a marine fuel are considered to outweigh the increase in basic cost. Diesel remains cheaper than petrol; is less volatile; can be stored in integral hull tanks; and the vapour, although pungent, is much less dangerous than that of petrol. <font color=blue>Diesel is also relatively more environmentally friendly than petrol.</font color=blue>"
<font color=red>Hands up all those like me who consider that this response is:
a. Fundamentally flawed as far as leisure craft are concerned.
b. Ignoring the real issues.</font color=red>
