Simon F
I have a Shakespeare V-Tronix Stub VHF Antenna mounted on the wind generator mast and the coaxial cable is deteriorating from exposure to the weather for the first 1.5 metres but the remaining 10 metres of cable is ok and a previous owner has thoughtfully left, safe and dry within the cockpit locker, a tidy coil of the surplus coax which is sufficient to reach the antenna's mounting position. So, can I cut off the first 2 metres or so and connect the fresh end to the antenna?
I took it apart and it looks like the central conductor in the coax is soldered to a little connector which is bolted into the bottom of the antenna by a tiny Phillips head machine screw I can't see how the mesh shielding is supposed to terminate however. Has anyone rewired one of these? This seems to be worth repairing because if I buy a replacement, I'll have to run the new cable which looks like being more bother than fixing this. Is there the potential to damage the transponder if I get it wrong?
Thanks for any guidance
Simon.
Simon.
