Would prefer a small LCD (power consumption) any ideas? Also is it best to have an unidirectional aerial at the mast top or will an indoor aerial be OK in most places?
There is no point in having a unidirectional aerial at the top of the mast, because you would have to turn the whole boat around to pick up a signal. I think you will find an omni directional works better.
Anyway, you have gone down in my estimation just by contemplating putting a TV on board !
I use my home computer monitor Samsung syncmaster 171 mp ( have tuner ) for home and for boat TV - perfect ! Antenna is GLOMEX at the top of the mast for local stations.
Not go a bad word to say about it, oh, maybe one, there is no expansion card slot to upgrade freeview should you want to, maybe something I would have liked when we move aboard, but will not be important once we cross the channel, so a minute gripe.
Definitely recommend!
Edit>> Also from what I can fathom, it is not just freeveiw, but digital television, so should work abroad, hopefully, also it suggests that it will receive high definition television, I think!
I really do not think that a little LCD whould be suitable for such as GR. Go the whole hog and have a mains powered wide screen TV fitted. I'm sure you could rig a generator into some recess. Also, I find that it's best to have a large sofa on which to undertake one's viewing. This may mean some internal rearranging, but I'm sure it will be worth it given the vast array of interesting and stimulating progreammes that are available.
As to the aerial, I'm sure you could seek advice from a PBO chappie and see whether you can integrate an omnidirectional item into your black ball. The alternative would be fixing a unidirectional aerial attached to the boat's wheecher, and using a pulley system to keep it pointed in the correct direction while at anchor.
I don't hold with such new-fangled inventions - why don't you look out for nice Ferguson radiogram, circa 1962, in sapele veneer. It would help make your yoghurt pot so much more homely.
I think he should go the whole hog and make his own ... starting,say with binbags and tinfoil...old cigar box for the casing...save loadsa money as well!
I bought a cheap Beko Washer three years ago as a 'put on' until I moved and bought a fancy new one. It is used twice a day every day of the year by SWMBO (so she tells me) and is still working. It is a value line but if it lasts.....
I note that it has multi lingual menu displays. Does this mean that it is also switchable for PAL I & PAL G/B sound? This is important to us as our boat is in Greece.
yes, I have never seen this before and stuffed up the setting when I was first tuning it. Could not work out why all I was getting was hiss rather than decent sound. I had not realised how many standards there were and this little TV seems to have all of them.
Don't know about secam though, is that still used in France?
