dankilb
We’ve got the mast down and are redoing all the standing rigging. I’ve disassembled our late-80s Pro Furl 420 roller furler and a mechanical, winch handle operated, backstay tensioner (of unknown make).
I now need a suitable grease to reassemble the sealed roller bearings inside the furler (top and bottom for the ProFurl) and the gears and small bearing inside the tensioner. The furler had some thick yellow grease in there and had never been disassembled. The tensioner had some red, slightly translucent grease and had tool marks suggesting it had been serviced before.
I’m presuming I ought to use a grease with some moly ( with all those stainless bearings, gears, threads, etc.)? All I have currently is bog standard (EuroCarParts!) moly as used on car bearings and ‘marine’ plain lithium in the grease gun.
I was picking some other bits up from a local engineering supplier and they had moly greases ranging from £7 (Fuchs Renolit) to £12 (Moly Slip Arvina). Both claim high load/pressure qualities and washout resistance, and specify suitability for bearings.
Any thoughts or recommendations?
TIA!
TIA!
