cat007
New Member
Hey all
It's coming up on summer here in New Zealand and when doing my pre-summer checks I've noticed my engines raw water pump is leaking water quite badly.
This is about the 3rd time it's done it - maybe 4th even.
Last time I replaced the shaft for fear it was worn and chewing out the seals - this time I'm not sure why this is happening. Perhaps the seals I'm using aren't up to scratch? I've been buying the pairs of seals and bearings (sealed bearings) from a local bearing distributer.
I have been put off for buying them from my local marine engine supplier as they are, no kidding, 4 times the price....
Has anyone else had issues with their Bukh's raw water pump causing constant rebuilds? Perhaps my brass housing is warped somehow?
I really don't want to spend the $13 per seal and $30 per bearing, only to have it fail again in a couple of months....
