unclebraddah
Active Member
Aloha. Anybody ever tear into one of these. A belt driven Starter Generator. The threaded post receiving the Power(from solinoid) started spinning and the dynastarter stopped turning.
I openend it up and saw bigger copper wires comming from each of the 4 windings(Copper wire wrapped plates attached to the body). The looked unhinged perhaps broken. So I soldered them together to the power post. I put two brushes on (with wires to the Wrapped plates) and everything was fine. I put the other two on and it started shorting. Basically I believe the body is a ground. When I attach the two brushes without winding plate attachents it puts a + current through the body.
Im trying to figure out how this thing works. By my reckoning...The power goes in to all winding plates and creates the current causing the shaft to spin connecting to the brushes bringing current to the D+ and field post(which I dont use as I have an alternator). I use the Dynastarter to turn the engine over. ant diagrams or understanding how these things work so I can put it together would be greatly appreciated. Thanks!
