Rebuild of masthead crane on Golden Hind 31 Cutter
wwaites
New Member
24 Oct 2021
Removing the mast on Hale Kai revealed a surprise. There is a substantial masthead crane in stainless steel. This is not the surprise, it's pretty obvious from deck level. The surprise is that it was squint. The stainless piece is fixed to a smaller underlying aluminium piece, which is continuous and passes through the masthead, is badly cracked and bent.
The stainless piece contains a couple of sheaves for halyards for the foresails, in poor condition, with their pins welded in, so not easily replaced. The single foresail halyard that was fitted was instead passed through a block hanging on a pin. There are two pins for the twin forestays and a welded loop for a spinnaker halyard. The stainless piece is fixed to the aluminium piece with two pins and a screw. The backstays are connected to a double toggle which hangs on a pin through the aft part of the aluminium piece. All pins are 8mm or 5/16".
Cap shrouds are fitted to tangs that on a bolt that passes through the mast section. It is unknown if there is any reinforcing sleeve on this bolt apart from the aluminium piece mentioned above.
Some photographs: rigging
The question is, what to do about this. So far, there are two ideas:
  1. Fit a piece of stainless rod through the aluminium piece with special fittings to hold it tightly in compression, fore and aft. Replace the stainless crane over this. This is simple, but not the most elegant.
  2. Manufacture a sleeve with a tubular section that goes over the top of the mast with new cranes welded to it. This could involve cutting off the small aluminium cranes or fitting over them. This could be made in aluminium and welded. It could also be done in stainless (heavy) or titanium (lighter, somewhat expensive) and riveted.
Other ideas or suggestions?
These may help. The first is from the 1980 cutter rigged ketch, the second from a 1981 cutter rig, third from a 1977 with a bowsprit but not an inner forestay (this looks like a variation on mine) and the last from a 1980 with an inner forestay and add on in mast.
From what I can see the first one is similar to yours.
