donncha
(I have also posted this on the yanmar help forum)
I was going to do the simple task of changing the anode in my 3gm30. I had left the manual at home and being the ejit that I am, looked about the engine looking for the anode fitting. I saw what turns out to be the fuel injector limiter on the front face of the engine and proceed to undo it with a 19mm spanner. Once I had removed the front cap (number 1 in the pic) a threaded (brass?) rod with a small bolt head visable in it appeared. I the removed the second nut (number 2) holding the threaded rod in( the one on the outside, not the small one). When I eventually realisied that had something very foolish I reassembled the whole lot as best as I could remember it went.
Just to clarify I didn't touch the small nut actually in the brass rod at all.
When I got home I looked in the manual to discover what I had done. It strongly recommends not to tamper with the fuel injector limiter or the governor for any reason. Can any one please tell me if I has succeeded in causing damage already and is there a remedy to this very foolish messing.
