Re-inflating Anchors
oldbilbo
17 Jan 2012
West country
A different kind of Anchor thread.....;)
I have a number of fenders made by Anchor Marine of Tiverton, and I'm struggling to find an effective way to reinflate them. I've spoken with the company and it emerges that the valve-type I have is no longer used by them - and thus the Anchor re-inflation kit I bought doesn't fit into those valves.
The Anchor employee who took my call didn't know anything useful about the older type valve, other than that she didn't know anything about them. A request to speak with someone else who DID know resulted in a promise to have someone call me back. 'Someone' didn't bother.
So, in the absence of useful customer support from Anchor Marine, is there knowledge hereabouts of the structure of this older, deeper, valve type and what might be needed to re-pressurise the units? :confused:
sarabande
6 May 2005
I have various injectors and valvey things. If you post a pic, we might be able to match them up.
jon711
21 Sep 2007
Chester, Cheshire, UK
If it's like the one's we used to use on the hire fleet, we just used to stick the compressor airline onto the valve hole, but they may have changed (I am talking of 20ish years ago!).
Jon
dutyhog
13 May 2009
Argyll, Scotland
The compressor that I keep in the car for tyres has an adaptor that inflates our very old Anchor fenders. It's like a stainless steel hypodermic needle, about 2mm outside diameter (from memory). The other end is the same as a car tyre valve. A small black plastic plug has to be pulled out (with pointed pliers) of the fender.
Anchor's web site has helpful hints on pressure etc.
PS I've found that these vinyl fenders can be patched with vinyl sprayhood sample material, with Evostick.
oldbilbo
17 Jan 2012
West country
This is the re-inflation kit that didn't work, for the hypo-needle doesn't extend deep enough.
I asked Anchor for a solution, more than once. The silence is deafening.... :distress:
dutyhog
13 May 2009
Argyll, Scotland
The metal part looks the same as mine. Did you push it all the way in to the knurled section? There is quite a lot of resistance, and it feels like you're puncturing the fender, but I suppose there's a tight rubber seal like many inkjet cartridges have.
PCUK
29 Jun 2005
Westleigh, Nr Tiverton, Devon.
My fenders had a stopper over the valve and a ball inside the valve. I pulled out the stopper, pushed the ball inside the fender and stuck the needle thing into the hole. Then inflated until hard. Put Sikaflex on the stopper and pushed back in. Seemed to work OK as they stayed up for several years.
FishyInverness
12 Oct 2010
Inverness
www.gaelforcegroup.com
Jon
+1 Air with sufficient pressure is going to open the one way valve with less hassle than trying to stab it with a blunted needle ;)
Works fine on current Polyform valves.
DaveS
25 Aug 2004
West Coast of Scotland
Possibly Fred Drift, but I had a fender that had a valve with a ball in it that wouldn't hold pressure, despite much messing about, trying to lubricate / clean it out, etc. I eventually made up a tapered plug out of Sugru which did the trick and it has now held pressure for several years. A plug for Sugru (pun intended) it's very versatile stuff.
sailorman
21 May 2003
Here or thertemp ashore
just force the airline terminal against the orifice works for me
sailorman
21 May 2003
i used silicone on an almost new one i found in the skip. The downside is the fender has the word Bavaria moulded into it
