tomsfisher
New Member
I have recently bought a wooden Folkboat built in 1962. One of the many tasks I have to undertake is to re-fasten the clinker hull strakes to the floors ( I think this is the correct term - I am referring to the structures that sit on top pf the keel and through which the keel-bolts pass. Most of the existing floors are not tightly secured to the hull. The challenge I face is that the heads of the existing bronze screws simply crumble when one attempts to apply a screw driver. I have started the process of drilling out the screws that fasten the strakes to a broken/rotten floor. The experience to date has not been encouraging. Keeping the drill in the centre of the screw and avoiding damaging the wood around it has proved impossible. I now have a couple of eliptical holes rather wider than the original screws. It may be that tackling the broken floor first was a mistake because the screws were either protruding into thin air (the floor having split across from side to side where screws entered it) or into very soft wood (at the bottom of the floor). I guess the screws therefore moved a lot in response to the drill and I hope this will not be the case with the other floors.
Does anyone have any tips about how to best proceed with this operation?
