Re-bedding through hulls.
bumblefish
22 Dec 2002
Brighton
There is an article in Sailing Today, (am I allowed to mention it here?) on installing seacocks/through hulls. They are bedded dircetly to the hull with no other material, other than sealant. All mine have a round of marine ply and I am about to re-bed at least 2 of them. Am I correct in assuming you only need to use marine ply if the curvature of the hull at the point of entry/exit precludes a good seal, so you shape the ply to fit or am I missing something?
All mine have round ply 'spacers about 3" (8cm) in diameter between the seacock and the grp hull.
Father's wooden boat is similar - but his are definitly 3" - its an old boat!
Suspect you can tighten more without damage to the hull and displaces any stress further.
Regards
Donald
Mine are all directly to the hull with sealant I think you are right about the ply taking up the profile of the hull.
Mine are bedded directly onto the hull but I use ply backing pads inside, pleanty of jallop on all the mating surfaces before tightening up.
Also, they showed a method for testing for leaks before re-floating, any hints on testing methods? Or are you so confident you don't need to?
Only use ply if the seacocks are metal. If plastic the expansion of the ply when it gets wet can crack the plastic through hull fittings
