JeanJeannie60
New Member
Can anyone help with a diagram how to rewire starter motor. Have new starter motor in place..but dont know where electric connetors go?. Thanx
Thankyou. I still dont understand why it doesnt matter though...As one is going to a live terminal and the other a negative...
Lets hope we dont reverse into anybody,s boat......thankyou.
If identical on bilge pump then it means either a series wound motor with field coil and rotating coil, so motor always goes same way as reverse of field coil is matched by reverse of rotating coil, however thats more usual on larger motors such as your vacuum cleaner so more probably a diode bridge etc in circuit so that motor and controls always see the same polarity whatever you feed in.
Your starter motor however might or might not be different. It wont harm it to spin the wrong way, but if not pre-engaged it simply wont turn engine if going the wrong way, and if it is pre-engaged it will turn engine the wrong way so wont start. Should harm nothing however unlike my mates old Isetta bubble car which had engine start in reverse in order to reverse and he got it wrong and accelerated swiftly from the garage but actually back through his fathers workbench
In the words of the old joke, that Focker was a Messershmitt!
The Isetta had a single cylinder four stroke engine, motorcycle derived, IIRC no reverse gear.
The three wheel Messershmitt had a 250cc two stroke engine, reverse capability achieved by a second set of points changing the timing to allow the engine to run in reverse.
As it would reverse at full throttle and the castor action of the front wheels was great, steering backwards was tricky!
Agree about the Messerschmit (sp?) or a Heinkel, but the Isetta had a four speed and reverse g/box. I drove a couple in the day.
There was a small <10 hp two stroke engine that didn't have a reverse gearbox. It had to be stopped , and restarted in reverse to go backwards or, more importantly, act as a brake. Someone will remember the name!
I believe the Isetta had 2 wheels at the back making it a 4 wheeler.
