tony_lavelle
My trusty old R10 radar worked OK when I bought my boat early last year but I had to cut the scanner cable in the cabin when the mast was unstepped. After launching, 9 months later, I reconnected the cable by soldering each of the 12 cores of varying thickness, some shielded and at least one coaxial.
Now the radar warms up OK but after it says "Ready" and I press the Xmit button, the display goes bright and there is a stationary vertical line and a loud continuous beep, interrupted briefly every few seconds. It does not respond to any buttons except to turn it off. The ammeter shows a current draw of only 1 amp, which seems low.
I gather the most likely fault is corroded terminals in the scanner unit (radome). However before I shin up the mast with a screwdriver and WD40, can anyone suggest what else I can easily check? I do have the original manual but my electronic troubleshooting skills are very rudimentary.
Tony
Tony
