concentrik
Can't get a response from Raymarine so thought I'd try here over the weekend.....
ST7000 + Type 2 Linear drive (ram) + Type 300 controller.
The old ram was sticking and RM said it needed new thrust bearing, planet gears, so I bought a complete ram secondhand.
This ram extends and retracts when connected to 12v.
Installed in the system however it doesn't work. Here's the sequence. The boat is moored:
1. Turn system on - display shows breifly "ST7000" then defaults to"STANDBY". ok so far.
2. Select AUTO. "AUTO" appears on the display. ok so far.
3. Call for ten degree turn by pressing +10. At this point the ram twitches, the display flashes "ST7000" and reverts to "STANDBY".
It happens every time. It's not the motor, I've swapped it. If I put the old ram back it is still a bit stiff, but it works - turn calls are acted on and it stays in "AUTO".
Baffled!
Baffled!
