Raymarine ST70 readability problem
NPMR
14 Feb 2006
Cornwall
Having just launched for the season, motored to the mooring, all systems looked to be in order, so switched everything off and left the boat.
On the next visit, 4 days later, switched all instruments on as usual, but this time one of the two Raymarine ST70 instruments the boat carries appeared not to be on. On closer examination, it was actually on (at certain angles it was possible to make out that the data was showing) but the screen looked as though the instrument was not on. So we know there is power and we know it is getting a signal from the transducers.
Some discussions later there is a body of opinion that the 'backlight' has failed. Has anyone else experienced this? And if so, was there a fix?
The lighting could be off or 1,2,3 levels and should be the same for all connected instruments. At any level, they should all look much the same therefore. There is also a contrast adjustment to be done when unlit, for which you may need to refer to the manual. Basically, you need to establish that the contrast is acceptable and that the illumination works.
